A5W4eXCNhzArsec's avatar
Aug 07, 2021
Rax48 wpa3 ssid not saved
My 5ghz guest network is using wpa3. However the ssid got stuck with the old name when I changed to a different name.
  • plemans's avatar
    Please explain this a little more in detail.
    "its stuck"
    are you changing it in the app? In the browser?
    How do you know its stuck? or what is telling you that?
    • A5W4eXCNhzArsec's avatar
      A5W4eXCNhzArsec
      I tried both in app and web. Same behavior.
      Original ssid was aaa. I changed it to bbb and saved. After save the ssid is still showing aaa.
      • plemans's avatar
        Tried a simple factory reset on it?
