setrio's avatar
setrio
RAX50 nat moderate and packet burst
Hi,
I just bought a RAX50 and I can't get the nat to open in games. Also, I get tons of packet bursts at the point of being unplayable (testing on COD: Warzone).
Tried to set NAT to open, enabled/disabled uPnP and port forwarding without luck. Also, disabled the protection app just in case and nothing changed.
I don't care much about nat to be open but packet bursts are a concern since I can't play any multiplayer game at this point. The issue is with the router because I had a Linksys before without any issues, so...
Any ideas? Any help would be appreciated
  • I finally just returned the product, it didn't work and support was useless
    • setrio's avatar
      setrio
      none, it goes directly to the wall jack from the internet provider.
      • plemans's avatar
        And that jack has something connected to it.
