daviddobromirov
Jul 15, 2024Aspirant
RAX70 Cable can not be detected
Hello,
My router out of nowhere cannot detect the modem.
I even tried factory reseting the router and then it says that cable cannot be detected.
I am out of ideas how to fix this.
Please help!
Thank you in advance!
Best regards,
David
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.- daviddobromirovAspirant
Current firmware version is v1.0.15.146.
Modem is Spectrum ET2251.
I now changed to CAT6 cable. I had some yellow garbage on it.
Yes, I turned off both modem and router for 2 minutes + and then back on, and nothing.
I factory reset and then I again redid the steps and nothing.
Best regards,
David
Can you connect a wired PC or laptop to the modem and see if the PC or laptop gets any internet?
