PhillipJ
Apr 22, 2020Aspirant
RAX75 keeps disconnecting the 5GHZ after and before firmware 1.02.76
Went through tech to reconfigure and updated firmware 1.02.76 on 4-21-2020. I connect with the 5G and it disconnects every 2-3 hours and then comes back on itself. I have a Xfinity networks.. Before using this Router I had a mesh network that NEVER once drop my connection but it was a little slow but never had a drop connection. It is frustrating as talking ton Skype or WebEx meetings I drop call. The mesh network I had is over 3 yrs old and might go back using it. This is a terrible lack of quality. Anyone had problems. I was advise to change channels on the 5G by the tech.. I still am disconnecting. The 2G somehow also gets disconnected sometimes. Case #42600598
- PhillipJAspirant
I cannot always do a reboot 2-3x a day... other routters I had.. there was never any need to do that
- Christian_RNETGEAR Employee Retired
Hello PhillipJ,
May you try disabling AX mode. Has support been able to follow up on your case?
Christian
