neoeksOr
Feb 26, 2019Follower
RAX80 - AX6000 Nighthawk AX8 8-Stream Wi-Fi 6 Router
TL;DR: Everything remaining the same. Changed router to RAX80; requires modem restart upon internet drop
I recently changed my router to the RAX80 after my old router burned out. I was already ...
mike1389
Mar 20, 2019Initiate
HEY NETGEAR,
THERE ARE MULTIPLE THREADS ALL CLAIMING THIS SAME ISSUE, I HAVE THE AX6000 AS WELL, HAVE POSTED IN OTHER THREADS, HAVE WASTED HOURS ON THE PHONE WITH YOUR TECH SUPPORT, WHICH FOR SOME REASON WANT TO TRANSFER ME 6 TIMES BEFORE FINDING THE RIGHT PERSON, WHO CANT ACTAULLY HELP ME. YOU KNOW THERES A PROBLEM WITH THIS ROUTER, START FIXING IT, OR START ISSUING REFUNDS. THIS IS REDICULOUS FOR A ROUTER THAT IS BRAND NEW AND 400 DOLLARS. THE WIFI RANGE IS WORSE THAN MY NETGEAR R6700, AND THE TECH SUPPORT IS A JOKE. TRY CHANGING YOUR WIFI CHANNEL AND CALL BACK IN A COUPLE DAYS. FIX THE ISSUE.
- Christian_RMar 25, 2019NETGEAR Employee Retired
Hello mike1389 - Send me a PM with your case number and I can assist with support following up on your case.
~Christian
