bdschwar
Sep 07, 2020Guide
RAX80 FW-Update 1.0.3.102 caused complete reset of router and outage
Dears,
I'm really upset: Having had issues with the buggy 1.0.3.98 version I updated today to the most recent version (1.0.3.102 by 4th September), and this rubbish completely resetted my router with all questions to be answered from the very beginning and without any connect possible (even restored the former settings) to init7, the most powerful Swiss provider.
I'm now back to 1.0.3.88 with all functions working again and definitely disabling aut-update functionality.
When will you release a proper actual version with an accurate description of side-effects within the release notes or are you netgear not interested in working professionally?
Regards
Bernd
- Christian_RNETGEAR Employee Retired
Hi Bernd,
Thanks for sharing your feedback. May you try updating to the latest firmware version manually using a wired device. Please let me know if your issue persists.
Christian
- bdschwarGuide
Dear Christian,
I never flash a device differently than connected wiredly and as FW-update-assisstant did not work, there was no choice than to try it manually. So the issue still exists and why should I have a new try with the same version as it's still the latest one?
My provider clearly stated no issues on his side, the router could/did not connect after applying the patch, so what do you want me to tell?I will not apply this rubbish again...
Regards
Bernd
