dmystic1
Dec 21, 2018Apprentice
RAX80 range is not that great
So, it seems the range is a little lacking. Using one Linksys Velop node placed in the same location would give me 5ghz and of course 2.4ghz to my outdoor camera. with the RAX80, I get zero signal....
Navymac
Feb 18, 2019Aspirant
I need a bit of help on my RAX80 setup. I heard that HT 80 and HT160 may give better range or performance. On my 7800 you could see where you could enable Ht160. On the RAX80 I cannot find that option.
- Firmware Version V1.0.1.40_1.0.22
- I've turned on QoS.
- 2.4Ghz
- Auto and 1,000 Mbps
- No coexist between 20 and 40 Mhz
- Security at AES only
- 5Ghz
- Its set at Mode 1,000 Mbps and Channel auto. FOund out you cant set Auto on higher Mode settings
- Security is set at AES only
