droidfan
Jul 08, 2019Aspirant
RAX80 slow Ethernet and wifi
I'm on firmware V1.0.1.58_1.0.24. I have QoS disabled, just installed the Intel AX200 wifi 6 chip in my Dell Inspiron 7568 2-in-1 in the m.2 slot, and tried transferring a file from a powered USB 3.0 hard drive connected to USB port 1 on the router. In the network status in Windows 10, it shows 2.4Gbps, connected to the 5Ghz network. Even at about 6 feet away from the router, I'm only getting 30 megabytes/s.
On another laptop next to the router, connected via 1Gbps Ethernet cable, file transfer from the same USB 3.0 hard drive connected to the router USB port 1 is only at 70 megabytes/s.
So i thought maybe the network share aspect was slowing it down, so I tried to transfer a file from the laptop next to the router connected via 1Gbps Ethernet, to my Dell about 6 feet away from the router connected via 5Ghz wifi, and it's still capped at about 27-30 megabytes/s.
These numbers seem pretty low, even after swapping out the wifi 5 chip with the wifi 6 one. Does anyone have any idea what to do about improving the speed? At least the Ethernet speed should be faster, right?
Which problem are you trying to fix? USB speeds? LAN speeds? Wifi speeds?
There won't be a single solution to fix them all, so take things a step at a time.
Let's start here:
Check this forum for discussions on the Intel device and the drivers you need.
- droidfanAspirant
I've already installed Intel AX200 driver version 21.20.0.5, dated 5/28/2019, and have selected '4. 802.11ax' for '802.11 n/ac/ax wireless mode' in the wifi chip properties, under the Advanced tab. I've also enabled AX in the router settings. Anything else I can do?
- droidfanAspirant
Just updated the Intel AX200 driver to 5/30/2019 version 21.20.1.1, and tried transferring files from the USB attached hard drive, and the speed is still capped at 30 megabytes/s. There must be something that is capping the speed. I set the 5Ghz wifi network channel to Auto, so it should find the best channel, right?
