dmystic1
Jan 17, 2019Apprentice
RAX80 specs
Does RAX80 support 802.11k? Even though the range is ok I still may need an extender. I was thinking of the xs6.
michaelkenward
Jan 18, 2019Guru - Experienced User
There is support for the RAX80, including a manual, at the end of this link:
>>>RAX80 | Product | Support | NETGEAR<<<
See the section Technical Specifications.
microchip8
Jan 18, 2019Master
My R7800 supports 11k but can only be enabled in the hidden debug page (http://192.168.1.1/debug.htm). Could be the same for the RAX80/120
- shadowsportsJan 18, 2019Hero
My 8000P doesn't support "k", either due to chipset or FW. Can you post your debug page for comparison? Thanks
- microchip8Jan 18, 2019Master
- dmystic1Jan 18, 2019Apprentice
I did not see a setting for it.
