Retired_Member
Feb 03, 2019RAX80 USB Printer not detected
I have a problem. After connecting different printers to the router using a USB cable. No printer is visible on my computer .My printer in not visible in my panel control printers.
Any idea?
Mac...
DarrenM
Feb 06, 2019Sr. NETGEAR Moderator
You may want to check out this Kb and get the usb control center
https://www.netgear.com/support/product/ReadySHARE_USB_Printer.aspx
DarrenM
Retired_Member
Feb 06, 2019Unfortunately this software doesn’t work with newest Mac OS X 10.14
