Retired_Member
Aug 22, 2020RAX80 very inconsistent discovery of local devices
Recently I have discovered my local devices are having trouble seeing each other, the only change I can think of is I assigned a few more static IPs and had a firmware update. Has anyone else exper...
- Retired_MemberAug 24, 2020
I actually finally troubleshooted the issue. The culprute is Netgears "Smart Connect"! A feature that is suppose to merge both the 2.4Ghz and 5.0Ghz SSID's into one and auto assign the best channel, it actually caused the issue instead. Simply turn it off and do what you must with now having 2 SSID's (In my case 5.0Ghz is hidden) and all works well no matter what channel you are on!
I even turned off and on every other WiFi 6 feature to make sure and they all work, just not smart connect! Very frustrating as I liked the feature but at least now I can dedicate 5Ghz to what devices really need it.
Retired_Member
Aug 24, 2020I actually finally troubleshooted the issue. The culprute is Netgears "Smart Connect"! A feature that is suppose to merge both the 2.4Ghz and 5.0Ghz SSID's into one and auto assign the best channel, it actually caused the issue instead. Simply turn it off and do what you must with now having 2 SSID's (In my case 5.0Ghz is hidden) and all works well no matter what channel you are on!
xjn
Aug 24, 2020Apprentice
Retired_Member wrote:I actually finally troubleshooted the issue. The culprute is Netgears "Smart Connect"! A feature that is suppose to merge both the 2.4Ghz and 5.0Ghz SSID's into one and auto assign the best channel, it actually caused the issue instead. Simply turn it off and do what you must with now having 2 SSID's (In my case 5.0Ghz is hidden) and all works well no matter what channel you are on!
I still had issues with Google equipment even with Smart Connect off from day one. I prefer separate SSIDs so never used that feature. If issue comes back I would check Google forum.
