thatrevguy's avatar
Jun 09, 2020
RAX80 Wireless Devices unable to see ethernet connected devices.
This is an odd one...
I upgraded firmware on RAX80 to V1.0.3.88_1.0.41 and now none of my wireless devices can reach ethernet attached devices on same local network. On the flip side wireless devices can see other wireless devices. All attached devices have access to the gateway and internet.
Resetting the router to factory defaults made no difference.
  • It looks like that firmware was just pushed out 5/29.
    And you've tried the factory reset.
    I'd open a support ticket with netgear if you're still within warranty just so they're aware of the issue.
    I'd then downgrade to the prior version of the firmware.
  • plemans's avatar
    • thatrevguy's avatar
      thatrevguy
      Guide
      Downgaded to firmware V1.0.2.76_1.0.35 and problem went away. Didn't even reset the router.
      • plemans's avatar
        Glad to hear you got it working!
        Did you get a chance to send a notice to the support team so they're aware of the issue?
