Blachowiak's avatar
Blachowiak
RAXE300 will not save short preamble for 5/6ghz
I am unable to set and save the short preamble preamble mode for 5GHz or 6GHz.
This issue has been raised in other posts for other routers. I can't find any resolution.
Router: RAXE300
Firmware: V1.0.8.64_3
  • FURRYe38's avatar
    Maybe due to that 5 and 6Ghz may not support that feature...
    • Blachowiak's avatar
      Blachowiak
      Are you saying that the option to select the preamble mode is not a supported feature? All three WiFi bands have their own drop down menu for this mode.
      • FURRYe38's avatar
        And when short preamble is selected and you select apply, what is happening?
