stepnup's avatar
stepnup
Guide
Feb 17, 2023
RAXE500 connected on 6ghz, frequently stops serving internet, requires disconnect/reconnect
Strange behavior on 6ghz channel with multiple adapters.  AX411, AX211, and AX210.
I connect for a few hours then internet stops working.  Still says I have internet (windows 11), but serving up web pages stops.  I simply disconnect/reconnect and all is well.   I am not seeing this behvior on 5ghz.  I am not seeing this on wired connections.  Been happening for a few months through multiple FW updates.
Internet is not the problem.  I can go to other systems on the network and internet is fine.  I can also still connect directly to the router when having no internet.. so wifi is still connected.
No QoS enabled, no traffic meter.  Enabled OFMDA on all channels, disabled wmm on all channels.  DHCP.  and a lot of connected devices ~85
Thoughts?
Currently AX411
FW V1.0.12.96_2.0.45
  • plemans's avatar
    What modem/gateway is it connected to?
    Strange behavior. My RAXE500 is currently in router mode and I'm not having any 6ghz issues with my AX210.
    • stepnup's avatar
      stepnup
      Guide
      Netgear CM2000 modem.
      Yes, it is like internet gets frozen.  Disconnect, reconnect fix it.  If I switch to 5ghz, no probelm.  On 6ghz it happens  few times a day.  Very close to router (20 feet) so interference no a problem.  Strong signal.  None of the other devices have connection problems when this adapter stops getting internet.
      Rob
      • plemans's avatar
        leave WMM enabled
        Is ipv6 enabled?
        Have you tried a different 6ghz channel?
