cabwav's avatar
cabwav
Tutor
Apr 12, 2024
RAXE500 timeouts
I recently installed a RAXE500 router. When selecting a menu item or switching to another menu item I have to re-enter the userID and password. The router also frequently reports ' timeouts', e.g. when I add an address reservation in LAN setup and I don't press the 'apply' button fast enough (within 2-3 seconds) the router requests the username/password again and displays the message 'Sorry,your timestamp is expired. Please click the menu to re-enter the page.'
What is causing this?
The NTP setting is set to the correct time zone, DST enabled, NTP server set to the same server as used by my Windows 11 install (time.windows.com). Router firmware V1.2.13.100_2.0.54
  • What browser are you using?
    Happens with other browsers? Try MS Edge or Firefox.
  • FURRYe38's avatar
