gs550t1981's avatar
Jul 08, 2020
recent update rax40
I did the update the router called for and now I need to reset the router atleast 5 times a day to get it working again. B4 the update it was fine. I am working from home right now so its kind of a big deal for it to work right. Is there a way to downgrade the firmware? Thanks
  • plemans's avatar
    Before downgrading, I'd actually factory reset the router and reinstall it. The RAX devices have gotten quite a few changes with the firmware updates and have responded well to a full factory reset and reinstall. That might help with your issue before trying the downgrade process.
    I'm thinking you maybe meant that you were rebooting the router. Not resetting.
      • plemans's avatar
        You can do it through the gui menu or using the hardwired button.
        menu----navigate to advanced-----administration-----backup-----erase
        hardwired-push and hold reset while powered on for 7-15 seconds.
  • What a pain in the ass..... won't they just fix this already with a new update?
