millewg001
Apr 29, 2021Aspirant
Regular loss of network connectivity
I have an RAX120 installed running with Spectrum 300mbs service with their MODEM. On a regulary basis, I lose all internet connections and random times. (3am, midnight, 4:30pm, etc). I've been assuming this is a spectrum problem and they have come to my house several times to check wiring, equiipment, etc. Recently they replaced the modem. It appears, from prior calls, there were service issues but yesterday, their service deck believes I was gatting a strong signal and I needed to check my router and wiring to the modem.
I am trying to figure out is there is a way with Netgears router (RAX120) I can determine if I have a router problem. I'll continue to report outages to Spectrum but am interested in thoughts or recommendation on how to assess if my router is causing these problems. Thoughts or suggestions?
When you have the outage, are you still able to access the routers interface?
And after that, are you able to ping/log into the modem?
- millewg001Aspirant
No, the only way I can connect is to reboot the router. I have been having a running issue attempting to determine if my problem is the router or Spectrum's model. The last 3 calls, my ISP service appears to be fine (per Spectrum Customer Suport) and I needed to either replace the cable between the router / modem, or reboot the routher. Both times, I was able to reestablish normal internet connection.
You say the only way to connect it to reboot the router.
What is happening when it drops?
Does your wifi signal disappear?
Does it say "connected, no internet"?
Are wireless and wired devices able to ping the router?
What are the led's doing on it when it goes down?
