TomK12
Jun 24, 2021Aspirant
Router freezes
Hi
I have my RAX120 for more den 1.5 years, and was very happy and satisfied with it until a few weeks ago
the router has the latest firmware 1.2.1.22
but from time to time (sometimes a few weeks, somtimes a few days) the router freezes, and no connect is possbile any longer
the only way the get my router run ist to turn it off and on again
i cannot check the logs to find out what the problem could be, butwhen turning off and on, the logs are cleaned
this situation is very unsatisfying
does someone else knows of similar problems ? does someone have a solution ?
greetings
Thomas
- Christian_RNETGEAR Employee Retired
Hi Thomas,
Did the issue began occurring on this firmware version?
Christian
- TomK12Aspirant
Hi Christian
It occurs with the latest firmware (1.2.1.22) more often as with the previous firmware, I am sorry but I cannot say by sure when this problem started to begin.
because after this happened more often, I tried to get information from the router log, so I configured the router to send me the log by mail once a day. and I started by the end of march, and as I mentioned before, I am not sure when I did install the latest firmware, but I think it was sometime in April.
best regards
Thomas
Hi Thomas,
You may try reverting to the previous firmware version to see if that helps with your issue.
https://kb.netgear.com/000062689/RAX120-Firmware-Version-1-2-0-16
Christian
