MichelleMattie
Jul 06, 2022Guide
Starlink & AX1800 WiFi 6 Router
I cannot get my new AX1800 router to connect to the internet through Starlink. I have plugged and unplugged it all. Still no internet. Any suggestions before I return the router? Thanks for your help.
Thanks for your help. I got it to work by bypassing the Starlink Router. LOL - this is not for the inexperienced and faint-hearted! 🙂
What router is it from starlink?
The only one I think that they have (non-business).
They've got more than 1.
Plus if you're cascading routers, you're in a double nat.
Try putting the netgear in access point mode and then connecting it to the starlink router.
