Johjohjus
May 28, 2021Follower
Still need a modem? Ax4300
Do I still need a modem to work with this ax4300?
What is your "this ax4300"? "AX4300" is a speed, not a model number.
Look for "Model" on the product label. RAX45?With that datum in hand, you might try a radical concept which works
for some people:https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read."still"? Did you need a modem before? With some other (unspecified)
router? The non-psychics in your audience might know very little about
your Internet service, or what your (unspecified) ISP might require, or
what you were using before, with what.A RAX45 is a router, with no built-in modem. If your service
requires a modem, then I'd expect your service with a RAX45 to require a
modem, too.- michaelkenwardGuru - Experienced User
Johjohjus wrote:
Do I still need a modem to work with this ax4300?How do you get the Internet?
If you have an Internet service provider that fixes some sort of box to the wall, that may be able to feed a router. But that is usually "fibre to the home" Internet.
A good place to ask the question is with the ISP that sells you the Internet service.
