baileyj0611
May 29, 2020Tutor
This RAX80 Is DRIVING ME NUTS
ALRIGHT.......First of all, the speeds of this thing are great, and the coverage is great - However, the interface is SEVERLY lacking - It's very amateur and I don't think tthis router should be ANYTHING amateurish.
I have multiple issues:
Running FW
1.0.1.70
Trying to update to latest, I guess which is
1.0.2.76 or 1.0.3.88
Doing it automatically through the interface, it fails.
So I download the file, manually upload it - states that "The Firmware File is Incorrect" - Alright, fine.
NOW WHAT?
The issue as to why I'm even updating is obviously security and whatever reasons, HOWEVER - I KEEP GETTING READYSHARE ERRORS!!! Both Mixed with Windows or MAC, the readyshare becomes unavailable - Windows states "An unexpected network error occurs" - Iv'e tried 3 different hard disks, differently formatted drives, USB3, USB2 - all of it.
Anyone else keep running into this?
I really really want to like this router.
TIA.
Justin Bailey
Sr. Systems Admin.
- Christian_RNETGEAR Employee Retired
Hi baileyj0611,
May you follow the article below to update the firmware manually. You may also try updating the firmware using the Nighthawk app.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Christian
man i've done this a trillion times, I'm tired of this router.
About to go back to Asus.
baileyj0611 - Send me a private message with your contact info and serial number. I'll see if support can reach out for further investigation.
Christian
