dt1000's avatar
dt1000
Trouble with Google Home Speakers on a Nighthawk AX12 RAX 120
I live in an old, brick house, which makes setting up a decent WiFi network reeeeally tough.
I recently purchased an AX12 RAX120 as it is widely regarded as having amazing range.
Everything works relatively well... apart from when I try and listen to music on a Google Home speaker.
When listening to music (from Spotify or BBC Radio) the signal cuts out intermittently, producing a terribly frustrating choppiness.
This becomes worse if I'm streaming on multiple speakers, as they all start to drop in and out at random intervals.
The speakers don't get amazing signal strength... about -75dBm... but it should still be enough to stream music.
Is there anything I can set in my configuration to make streaming smoother?
Thanks,
Dan
  • plemans's avatar
    What modem/gateway is it connected to?
    What firmware is on it?
    have you tried changing the wifi channels?
    • dt1000's avatar
      dt1000
      Thanks for the response! ❤️
      Here is the info you seek...
      Modem:  Hitron CGNV4 Router
      Firmware: V1.2.3.28
      Wi-fi Channels: I disabled auto-switching and looked at all the channels active in the area, then selected empty ones with space either side. Currently on 9 for 2.4GHz  and 48 for 5GHz.
      • plemans's avatar
        that hiltron is a modem/router combo device and can put you in a double nat. Some smart home devices struggle with a double nat.
        A double nat happens when you cascade more than 1 router.
        https://kb.netgear.com/30186/What-is-Double-NAT
        Fixes? There’s 3 options but only use 1.
        1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
        2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
        3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
        https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
