MightyMouse423
Aug 16, 2020Follower
Unable to change SSID and password
Hi, I am currently trying to change my SSID and password on my AX4 router but every time I try to apply the settings, it shows the loading bar as if it is going to chnage just to load and show the old ssid and password. The firmware is the latest V1.0.3.80_1.0.1, I've tried from the Nighthawk app as well as from the web browser of my computer while connected through ethernet and have gotten the same result. I am not trying to use smart connect and have even done a factory reset on the router with no change. Any other ideas on things I could try?
Thank you
Sort By
- Christian_RNETGEAR Employee Retired
Hi MightMouse423,
May you revert back to the previous firmware version and let us know if your issue persists.
Christian
- khleeAspiranti cant change time zone, my ssid, password..
everytime i changed, click apply, processing bar moving, after finished, nothing happened.. - khleeAspirantwhat is the previous firmware, where to download
khlee,
Please refer to the article below and on step 5, you may select previous firmware versions to manually revert back to.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Christian
