EastSider01's avatar
EastSider01
Follower
Apr 05, 2026
Upgrading from Netgear AX1800 to RS300
Hello: I just ordered a new Netgear RS300 router to replace my nearly 6 year old Netgear AX1800 router which will soon be unsupported.
Is there an easy way I can keep all my connected network devices and settings without having to re-enter them in the Nighthawk software when I upgrade to the new RS300? Will the Nighthawk software allow me to add the new router and delete the old one?
I have the Nighthawk app on my iPhone but have in the past used the Netgear program and screens on my computer for setup.
Any guidance would be much appreciated!
  • FURRYe38's avatar
    No. You'll need to set up the new router from scratch.
    However you can use same SSID name and password from the older router for the new router. Once that is set, you wifi devices should auto connect fine.
    Try WPA2 and AES Only at first, then try mixed WPA2 and WPA3. Some older device may not connect if WPA3 is present.
  • CrimpOn's avatar
    CrimpOn
    Most of the people who comment on the Forum seem to prefer the web administration approach over a smartphone 'app'.  Be aware that Netgear does not make it easy to avoid using the app.  There is often an almost invisible option along the lines of, "I do not have a smartphone."  There are some features and options which cannot be managed with the app.  (There are also features that can be managed ONLY using the app.)
    Since you have to do a complete setup, it is often helpful to go through the web interface on the existing router and make a screen shot of every page. Save them to a Word or PDF file so that you can refer to the information if needed.
    With so many people these days not owning computers, it is obvious that a huge number of Netgear customers configure their new WiFi router using the smartphone app and seem to suffer no ill effects.  (From the WiFi systems visible in my neighborhood, it is also obvious that a significant number of customers do not configure their WiFi systems at all.
