ssssss
Jan 09, 2023Tutor
What's the current status of RAX120 in 2023?
Thinking of buying "Netgear Nighthawk AX12", mainly use as AP. But I read lots of bad review regarding rebooting problem. What's the current status on this? solid enough after firmware upgrade?
so you'll see a lot of reports from them on here as this is the forum where people come with issues.
So you'll see it a lot of here.
but if you're looking for mainly an access point, why not just get an access point?
- microchip8Master
The RAX120 is a waste for using it just as an Access Point. If you need that, just get an Access Point instead of a full-blown high-end router. It's overkill to get the RAX120 and use it as a simple AP.
- ssssssTutor
plemans microchip8 For $200 range, you really can't get a good AP at this price. WAX615 only rated for AX3000 but weak cpu and memory.
If you really want the RAX120v2 then there is a patch that fixes the random reboot issues seen only on v2s.
