jdbyyc
Jan 19, 2025Aspirant
Why doesn't Attached Devices have 6G for a Connection Type?
I'm new to Netgear - is there something I'm supposed to enable?
In the Nighthawk app the 6G connection type / band is just absent; in the web interface it is represented by "--".
Is it a bug? If so, where can I see the bug reports? (I tried searching but didn't find anything.)
Thanks!
Your wifi device have to support 6Ghz.
- jdbyycAspirant
It does. The device that has Wifi 6E support is a line item that isn't a 2.4G or 5G connection type.
This is what it looks like in the web interface. The Macbook is a M3 and is connected to 6Ghz (option + click Wifi icon says so).- michaelkenwardGuru - Experienced User
Remember, you may not see a 6 GHz option, or any particular band, if Smart Connect is enabled in the router.
My Windows PC just shows a single SSID.
I have to dig into the entrails of Windows to discover that I have a 6 GHz connection.
I am too poor/mean to use a Mac so have no idea how it works there.
Just another user with time on their hands.
- KitsapMaster
jdbyyc wrote:I'm new to Netgear - is there something I'm supposed to enable?
Thanks!Your RAXE500 does indeed support the 6 GHz Wi-Fi band.
The smart connect feature does not always select the highest frequency band. Depends on the device you are connecting.
The Netgear mobile application has lots of holes/bugs. You might check the Netgear support community specifically setup to cover the mobile application.
Here is the link: https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
- jdbyycAspirant
This issue is the Nighthawk app and the web interface. So it would seem to be a value that isn't populated and therefore unable to the UI of both.
Have you set up the 6Ghz SSID name on the RAXE for a custom SSID name? Does the Apple device see this SSID name?
Be sure to disable Mac Address randomizer on the Apple device for the connection.
