Kyloh3n's avatar
Kyloh3n
WI-FI not connecting to any device in household
I have been trying to connect to the Wi-Fi all day and I called the ISP and everything is fine with the internet, I see the router is getting the internet, I checked on the app and web it is connected but it’s not distributing the Wi-Fi and I don’t know what else to do.
  • Would be helpful to know what NG router model your referring too.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
  • FURRYe38's avatar
    • Kyloh3n's avatar
      Kyloh3n
      Hello apologies it’s for the nighthawk ax5400 6 stream wifi routr. I’m trying those steps now, I was able to contact the ISP and everything was good on their side, I even plugged my laptop straight to the modem and it was working. I haven’t tried the factory reset settings but I may have to try that
