Bbtbbt
Mar 10, 2023Initiate
Wifi 6 Netgear RAX10
Can this router be loaded with Expressvpn
expressvpn literally has a site with what routers they support.
https://www.expressvpn.com/support/knowledge-hub/supported-devices/#routers
Its third party firmware and you won't find support for it on the official forums.
There are dozens of VPNs out there. Netgear can't test them all.
The best people to ask which devices support a VPN system are the suppliers.
So, talk to ExpressVPN
Duh, I should have known that.
Thanks for making up for my ignorance!
Might be a good idea for Netgear to create a KnowledgeBase article on VPNs with links to some of the better known services.
