Jaujla
Dec 21, 2020Follower
WNDR3800 Change
Hi,
Can someone advise what is the correct method in copying configuration details from WNDR3800 to AX12.
After I have swapped out the router can I
use the WNDR as a AP?
Thanks in advance.
Thanks in advance.
Jaujla wrote:
Hi,
Can someone advise what is the correct method in copying configuration details from WNDR3800 to AX12.-----I'd take a few screen prints or write them down. Then manually input them in.
use the WNDR as a AP?---You can. It has an access point mode.
Thanks in advance. - michaelkenwardGuru - Experienced User
use the WNDR as a AP?Visit the support pages:
Support | NETGEAR
Feed in your model number, WNDR3800, and check the documentation for your hardware.
Check the section in the manual Wireless Repeating Function (WDS).
