masterjdog's avatar
masterjdog
Internet Disruptions on WiFi (ethernet internet and wifi access to NAS not affected)
I have a Nighthawk AC1750 running firmware v1.0.4.128_10.0.104. For quite sometime I've had intermittent internet service disruptions for my wifi connected devices. It simply stops working, and requires I cycle the router. Key point is that when the internet disruptions occur, this does not prevent wifi connected devices from accessing my NAS or even my Netgear admin portal, nor does it prevent ethernet connected devices from accessing internet. I've tried factory resetting the router to no avail, and previous firmwares also had the same problems. I've also kept config to factory settings other than 1). port forwarding and UPnP for an ethernet connected device; 2). static IP for a couple devices; and 3). parental controls via Circle (although other than enabling I haven't even done any real config on parental controls since last factory reset). There also don't seem to be any obvious errors in the std logs I can access from the Netgear portal, but I don't claim to know much about what verbose logging options are available, how to access them, and what they can provide.
Does anyone have suggestions on what might be the issue, or how I could better troubleshoot this?
  • masterjdog's avatar
    masterjdog
    Oct 02, 2022
    Just circling back that I made a single change after this last post and simply disabled parental controls (i.e., Circle). It's been over a month and alls been great since...consistent high wifi speeds, not one wifi outage, and haven't had to bounce the router (these outages had been going on for as long as I can remember and occurred with a frequency of no longer than every few days). Not sure if there's a known problem with parental controls specifically affecting wifi (and not wired connections) and don't have much interest in troubleshooting further, but wanted to provide an update for anyone who may be running into something similar in the hopes it may help. Thx to those who weighed in.
  • FURRYe38's avatar
    What model router do you have? AC1750 is a speed.
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
      masterjdog
      R6700v3 is the Nighthawk model. The modem is a Arris SB6183. Ethernet cables are all CAT6. And just to clarify, all the ethernet connected devices run through my Nighthawk as well, not direct to the modem.
      • FURRYe38's avatar
        Does the front LEDs show any indication of a problem when this happens?
        Has a factory reset and setup from scratch been performed since last FW update with out using any backup configurations and not enabling Access Controls, Armor, Circle or Traffic Meter?
        Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
        Be sure there are no coax cable line splitters in the between the modem and ISP service box.
        Be sure your using good quality RG6 coax cable up to the modem.
        Be sure to power OFF the modem for 1 minute then back ON.
