EnriqueLindo
Mar 10, 2023Follower
Conectar un rbw30 a un Rbk852
Hola necesito ampliar mi cobertura en una recamara, es compatible el RBW30 con un sistema mesh RBK850? Aún que no tenga la misma velocidad es para ampliar cobertura?
michaelkenward
Mar 11, 2023Guru - Experienced User
While there are some cunning linguists around here, you might get more help over in the appropriate section for your language.
