jdmarlow
Jan 05, 2022Guide
XS708T Connection is very slow, especially with LAG enabled
Hi everyone, I just purchased a Netgear XS708T 10 Gbit ProSafe Managed switch. My hope was to be able to set up a dual-10GbE connection with two Mac computers. Each computer has a 2-Port 10GbE ...
jdmarlow
Jan 05, 2022Guide
Bob thanks for such a fast and helpful reply. And thank you for the clarity that 10 GbE LAG won't achieve 20 Gb/sec to client. I may end up just going without a LAG connection in that case, since it seems to be a bit faster overall. I'm leaning toward eventually getting a NAS but at the moment my hope is to just be able to mount drives across a network over SMB and achieve a rightful 10GbE speed (or as fast as the drive speed can achieve if that is slower).
I suppose in this case I'll hold on to the XS708T unless you think I would do better with the QNAP for a more reliable 10GbE connection overall?
jdmarlow
Jan 05, 2022Guide
Just for reference...these are the comparisons between my NVME drive on one client computer. The faster one is local disk test. The slower one is over a single link 10GbE switch with the XS708T. Still seems pretty slow to me....
- jdmarlowJan 05, 2022Guide
Here is the screen shot of network speed...
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
