artkaos
May 05, 2016Aspirant
Disques de taille différentes en RAID 5 c'est possible ?
Bonjour a tous, J'ai actuellement u RN104 avec 4X1TB en XRAID5 Cela me donne un stockage de presque 3TB Que se passe t il si j'enleve un HD de 1TB et que je le remplace par un HD de 2TB ? V...
- May 06, 2016
Hello artkaos,
It needs to be at least to to have increase in volume size.
If you replace fewer disks than required for vertical expansion, the disks are reserved for data protection. Your available storage capacity does not increase to accommodate the reserved disks until you replace the required number of disks.
Please see How do I vertically expand an X-RAID 2 volume on my ReadyNAS OS 6 storage system? article.
This RAID calculator will also help you know how much volume you get with combination of different sizes.
artkaos
May 06, 2016Aspirant
THANK'S a lot for the raid calculator !
I Love :D
JennC
May 07, 2016NETGEAR Employee Retired
Hello artkaos,
You're most welciome.
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- artkaosMay 07, 2016Aspirant
Ok thank's :)
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
