EliRap
Sep 25, 2019Aspirant
No login possible
Hello, i am new here and i have following problem:
When i login into routerlogin.net or http://192.168.1.1 etc and enter, the link will send me to http://homerouter.cpe which is a huwei login, but I am having a Netgear Router...
Probably this is because i have enterd the password once too often wrong, thanks to an
unfortunately accident.
Please help me:robotsad:
Ok Thanks to your Information that i was connected to the modem, I looked the problem myself up and could solved it :)
The real problem was, that i was using accespoint instead of router, This sadly didnt work before where i was pressing the countinus button like crazy (yes i tried it with more attempts ) without anything happend and the acces point always worked so i thought it was nesscary... But after I changed my ethernet ip to 192.168.1.1 I was also able to click on this one. from there i went to advanced settings but was still not able
to access the internet so I loged out and a login again and it worked.
To be fair I still dont understand it...
Still thanks for your time
