Slimoune
Apr 29, 2026Aspirant
Impossible de se connecter RNDU2000
Bonjour à tous, Depuis quelques jours je n'arrive plus à me connecter à mon ReadyNAS Ultra 2 (RNDU2000). Je n'ai pourtant pas fait de modif du mot de passe. J'y accédais via l'explorate...
Sandshark
Apr 29, 2026Sensei
I'm not completely following what you are saying (I have to use Google Translate), but an OS re-install does not set the IP address to 192.168.168.168. It sets it to DHCP and the default IP that gets set when DHCP isn't working is 192.168.168.168. If you are trying to connect to the NAS directly with your computer rather than via a router with DHCP, you can address it via that IP address, but the PC will also have to be set to an address in the 192.168.168.xxx range.
Slimoune
That's what I did. I connected the NAS directly to the PC. I reset the password, but I'm not receiving the password.
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
