Slimoune
Apr 29, 2026Aspirant
Impossible de se connecter RNDU2000
Bonjour à tous, Depuis quelques jours je n'arrive plus à me connecter à mon ReadyNAS Ultra 2 (RNDU2000). Je n'ai pourtant pas fait de modif du mot de passe. J'y accédais via l'explorate...
Slimoune
Apr 30, 2026Aspirant
Excuse me, perhaps I wasn't clear. Yes, indeed, I no longer had the username/password prompt.
I reinstalled the OS, and the prompt reappeared. When I go to "configure" in Raidar, I have an address in the format 192.169.168.168/admin, but unfortunately, the username: admin and the password: netgear1 don't work!
Yes, Raidar correctly detected the NAS and all the indicators are green
Sandshark
Apr 30, 2026Sensei
Has your NAS been converted to OS6? If so, the default password after an OS re-install is password.
- SlimouneApr 30, 2026Aspirant
I tried both passwords, nergear1 and password, but without success. I don't have OS6. Could it be the osreinstall procedure that isn't working? Here's what I do: I press and hold the reset button, then i press the power button and release it immediately. I continue holding the reset button until all the LEDs light up. In my case, the power LED doesn't light up, and in fact, it doesn't turn on or off. The LED must be faulty. I then release the reset button and select disk 2 using the backup button. Finally, I press the reset button again, and the NAS restarts.
Thanks for your help.
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
