kitano77
Sep 15, 2014Aspirant
mise en veille et coupure nas RN102
bonjour, j ai activé la mise en veille du nas, pour tous les jours et toutes les heures, avec l option cochez wake up on lan mais j ai l impression que mon nas n est jamais en veille, toute...
EskenderNG
Sep 16, 2014NETGEAR Employee Retired
Bonjour kitano77,
I hope it is ok for everybody that my reply is in English.
First of all, Power timer („Programmateur“) is not sending the device to standby after a certain period of time, it is rather a time plan for booting up and shutting down the device.
Therefore, Power timer („Programmateur“) only works if some periods are set to on („Activé“) and others are set to off („Hors tension de jour/nuit“). They cannot all be set to off. It might be possible that with all periods set to off, that the ReadyNAS shuts down once at the beginning of each new week. But I am not sure about that.
Once the Power timer („Programmateur“) shuts down the ReadyNAS automatically all LEDs on the front panel will be off. The only LED still on will be that of the LAN port. Be advised if Power timer („Programmateur“) is used, the ReadyNAS will shut down regardless of any activities.
Regarding Wake-on-LAN, how do you attempt to wake up the device? Also, keep in mind that LAN port number 1 must be used for WoL to function correctly.
You may reply in French if you wish.
Bye,
Eskender
Bye,
Eskender
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
