fabri866
Feb 22, 2026Aspirant
ReadyNAS 426 - Modules kernel réseau manquants après tentative de réparation
Bonjour, Je possède un ReadyNAS 426 (N° de série : 511174EX0007E) sous firmware ReadyNAS OS 6.10.10. Suite à des manipulations malheureuses conseillées par une IA, les modules kernel réseau s...
- Feb 22, 2026
Sandshark wrote:
Assuming you've made all the necessary changes to the apt sources to account for Debian Jessie being archived, I think you can install it via apt. It's named kernelplus_1.0_all.deb.
First, that is what installed the files.
But this can no longer be installed, even with the apt changes. kernelplus installs another netgear package called linux-image-extra from apt.netgear.com. You get a 403 error when you try to install that package.
fabri866 - check your PM mailbox (upper right of the forum page)
Feb 22, 2026Guru - Experienced User
fabri866 wrote:Following unfortunate manipulations advised by an AI, the network kernel modules located in the /lib/modules/4.4.218.x86_64.1/kernel/net/ folder were corrupted and then accidentally deleted.
I tried to restore them by reinstalling firmwares 6.10.9 and then 6.10.10 via the administration interface, but these reinstallations did not restore the missing /net/ folder.
Something strange here, as that folder does not exist on my system (RN526)
root@NAS://lib/modules/4.4.218.x86_64.1# ls -als
total 292
0 drwxr-xr-x 1 root root 350 May 22 2023 .
0 drwxr-xr-x 1 root root 32 May 2 2023 ..
0 drwxr-xr-x 1 root root 4 May 2 2023 3rdparty
64 -rw-r--r-- 1 root root 63346 May 2 2023 modules.alias
68 -rw-r--r-- 1 root root 67334 May 2 2023 modules.alias.bin
12 -rw-r--r-- 1 root root 9732 May 2 2023 modules.builtin
12 -rw-r--r-- 1 root root 12081 May 2 2023 modules.builtin.bin
8 -rw-r--r-- 1 root root 7108 May 2 2023 modules.dep
16 -rw-r--r-- 1 root root 12376 May 2 2023 modules.dep.bin
0 -rw-r--r-- 1 root root 0 May 2 2023 modules.devname
4 -rw-r--r-- 1 root root 3540 May 2 2023 modules.order
4 -rw-r--r-- 1 root root 55 May 2 2023 modules.softdep
48 -rw-r--r-- 1 root root 45794 May 2 2023 modules.symbols
56 -rw-r--r-- 1 root root 54675 May 2 2023 modules.symbols.bin
Perhaps these were added when you installed docker?
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
