fabri866
Feb 22, 2026Aspirant
ReadyNAS 426 - Modules kernel réseau manquants après tentative de réparation
Bonjour, Je possède un ReadyNAS 426 (N° de série : 511174EX0007E) sous firmware ReadyNAS OS 6.10.10. Suite à des manipulations malheureuses conseillées par une IA, les modules kernel réseau s...
- Feb 22, 2026
Sandshark wrote:
Assuming you've made all the necessary changes to the apt sources to account for Debian Jessie being archived, I think you can install it via apt. It's named kernelplus_1.0_all.deb.
First, that is what installed the files.
But this can no longer be installed, even with the apt changes. kernelplus installs another netgear package called linux-image-extra from apt.netgear.com. You get a 403 error when you try to install that package.
fabri866 - check your PM mailbox (upper right of the forum page)
Sandshark
Feb 22, 2026Sensei
Feb 22, 2026Guru - Experienced User
Sandshark wrote:Assuming you've made all the necessary changes to the apt sources to account for Debian Jessie being archived, I think you can install it via apt. It's named kernelplus_1.0_all.deb.
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
