alaincodeville
Feb 18, 2021Aspirant
Webdav et https sur Windows 10
Bonjour, Voici ma problématique: Après avoir fait marcher Webdav en http , et mapper une unité logique en http , PC remote. Je veux passer en https donc ouverture du port 443 sur la livebox (route...
Feb 18, 2021Guru - Experienced User
Does https://router-ip-address/admin work when you are not on your home network? (using the external (WAN) address of the router?
If not, then either something is wrong with the port forwarding in the live box or (less likely) your ISP is blocking 443. I'm guessing that the 443 traffic is going to the live box admin page, and not being forwarded to the NAS.
alaincodeville
Thanks for your response.
I use //IP public address livebox/shared folder
And on the livebox , I has mapped the internal port 443 on the IP internal NAS
I proceed as for the port 80 on the livebox, on the PC windows10 the syntax command for Http is http://IP public address livebox/shared
folder , in this case it is working well
for Https it replece http by https https://IP public address livebox/shared folder and then i have the message "Echec d'ouverture de session sur le réseau"
Best regards
- alaincodevilleFeb 18, 2021Aspirant
Bonsoir,
je vais modifier le NAT sur la livebox, mais comme je dois me déplacer pour le faire, ce sera la semaine prochaine
bon week end
Améliorez vos compétences avec la Netgear Academy - Formez-vous, certifiez-vous et restez à la pointe de la technologie Netgear !
Rejoignez-nous!
