stevo_no1's avatar
stevo_no1
Follower
Jul 17, 2017
!!! Advice on getting open nat types, Xbox ones !!!
hi there, im not the best at this so please try and keep it simple.
in the house there are 2 xbox ones, a gaming pc, multiple laptops and mobile devices
we are currently with virgin media and have tried everything to open both the nat types on the xbox's but it only creats a temporry fix, we have been told to get a gaming router but i dont know where to start. i need one that is easy to use and that will allow permenant open nat types.
also if possible i dont want to break the bank it has to be affordable. hopefully someone caan help me out.
thanks
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello stevo_no1
    You should just need a router that allows port forwarding or able to put devices in the DMZ.
    DarrenM
