Scuttlebutt
Mar 25, 2017Tutor
+++++++++++ NETGEAR N450 Disconnects Once every hour on the dot - DHCP ISSUES +++++++++++++
Model: NETGEAR N450 (CG3000Dv2) N450 WiFi Cable Modem Router Firmware: V3.01.06 OS: Windows 7 Enviroment: Single Modem, no router, direct wired connection My n450 was working fine for a couple...
Scuttlebutt
Apr 07, 2017Tutor
Also how come the manual the the N450 gives instructions on how to modify the DHCP timer but the interface does not reflect the instructions?
TheEther
Apr 08, 2017Guru
Where do you see that?
To see the logs, log into the router. In the main menu, under Maintenance, select Event Log.
- ScuttlebuttApr 08, 2017Tutor
It won't let me post the logs on these forums so I had to screenshot it.
- TheEtherApr 08, 2017Guru
I don't see anything there related to your issue.
I did find the place in the manual where you saw the lease time and it, indeed, shows a 3600 seconds, which is 1 hour.
In your original post, you said that you can't find the LAN IP link under Advanced options. You can see it below (source:portforward.com). Look on the left of the image. If you don't see on your modem, then can you post a screen shot?
