sancarod's avatar
sancarod
5G connection unestable while 2.4 works
My 2.4 connection works but when I tried to connect to 5G it does not. Never had this issue before. I already tried to disconnect the router but it did not work. I also verified the status of the connection on the app but everything seems to be working. I called the internet provider but they mentioned there are no issues with the network.
  • FURRYe38's avatar
    Do wired devices work ok?
    What devices are you connecting to the 5Ghz radio?
    Is Smart Connect enabled or disabled.
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
