Brian1955
Dec 09, 2021Follower
5G Droping signal intermittently with CAX30
I had problems with the router dropping the 5G signal and difficulty logging in and constantly. Numerous factory resets and trying changing settings didn't fix problems. Spent a great deal of time with with tech support without resolution. Well I got some more shop light from Costco to add to some older ones I had in my garage. Included with the light was a note that the lights could interfere with some wi fi signals in the range that use 5.8ghz. I had to change to router channel to channel 40 and there is no more 5g issues. It interferes with the channels from 149-165. Hopes this helps some one.
Thanks for letting us know. Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there or benfit from your information:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you. - FURRYe38Guru - Experienced User
Enjoy.
