victorrt24
May 23, 2025Tutor
5ghz WiFi not uploading files
I also have this Issue. can anyone help. this only happens on 5g. i have to also switch to 2.4 to upload anything. even my out look email will not work on the 5g. only resetting my modem works and on...
May 24, 2025Guru - Experienced User
victorrt24 If you start your own thread, you'll get help directly with your situation. (we also encourage users to have their own thread so their troubleshooting doesn't get mixed up with the OP)
Makes sure to post your device, firmware on it, a good description of the problem, and what you've done to try to resolve it.
- victorrt24May 24, 2025Tutor
I appreciate the feed back but as mentioned there is already multiple threads on this without a solution. Same modem same issue. We just need a solution.
- plemansMay 24, 2025Guru - Experienced User
And if you want help, please don't thread jump to get it. Its part of the terms and conditions. Its fine to chime in and say "me too" so the mod's know there's more people with the issue. But if you're actually wanting help, then you need your own thread to not confuse what's being done with the OP and you. Here's the T&C
- Behave with civility and mutual respect. Flaming or name-calling will not be tolerated. Similarly, any message containing the following will be removed at the discretion of either a Community moderator or administrator.
- Off-Topic posting
- Thread hi-jacking
- Spamming
- Cussing or other profanity
- Ranting
- Providing personal information of others including last names and contact information
- Discussion or suggestions involving illegal activities
- Linking or posting of pornographic material
- Linking or posting of advertising, promotions, contest materials that are Non-NETGEAR provided
