victorrt24
May 23, 2025Tutor
5ghz WiFi not uploading files
I also have this Issue. can anyone help. this only happens on 5g. i have to also switch to 2.4 to upload anything. even my out look email will not work on the 5g. only resetting my modem works and on...
May 27, 2025Guru - Experienced User
Which ISP are you using with the CAX80?
What device are you using to upload data from? Brand and model#.
Does this happen with Smart Connect enabled?
Does this happen with AX mode enabled or disabled?
What channel configurations are currently set on the modem?
Is IPv6 enabled or disabled on the modem?
victorrt24 wrote:I also have this Issue. can anyone help. this only happens on 5g. i have to also switch to 2.4 to upload anything. even my out look email will not work on the 5g. only resetting my modem works and only temporarily.
