Space_Nomad
Dec 29, 2015Follower
5ghz Won't Show Up
I have a Netgear Router R6050. Recently someone in my household decided to let a friend change some settings to the router and now the 5Ghz doesn't show up anymore. It will only be shown when I'm con...
TheEther
Dec 29, 2015Guru
Either the entire 5 GHz network has been disabled or SSID broadcasting is turned off. Log into the router and check both conditions.
Otherwise, perform a factory reset and set up the router from scratch. You might want to change the admin password to prevent this from recurring. You will have to physically secure the router or else they can simply push the reset button to gain access.
