Reecek
Nov 16, 2015Aspirant
790S to replace a 3G21WB
Hi after a nasty electrical storm my old 3G21WB with external antenna died. After a lot of frustrating calls to Telstra they sent me a replacement, a Netgear Aircard 790S. My old modem was connected...
- Nov 17, 2015
Hello Reecek
If you able to use WIFI instead of LAN it will work just fine but if your looking to have LAN ports you would need to get the Netgear Aircard cradle this gives the card Ethernet slots. You can also tether with usb to the computer if you cant use wifi.
DarrenM
