anteater
Nov 20, 2018Aspirant
AC 1750 Orange / Red light on my nighthawk router trying 2 #7 cables , Samsung TV Mod #UN55JU6700
- Nov 26, 2018
It's an AC 1750 (6400 Vs 2). My solution was to switch back to WiFi to get rid of the distracting red orange light based on all the information supplied by this great community. I don't know how to check the wireless speed of this connection but the my 2k and 5k lights have gone from allegro to presto. I admit I stopped researching the 10/100 mbps connection for my particular TV because of all your input (which without would have driven me nuts) and life is too short! Thank you all!!
antinode
Nov 20, 2018Guru
> AC 1750 [...]
Not a model number.
> Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Is that accurate?
> [...] Orange / Red light on my nighthawk router [...]
Which "light"? Amber? The User Manual for a C6300 is a little
vague, but I'd guess that your TV has a 100MHz Ethernet port (which is
faster than it needs), not a gigabit port, and the "light" color
indicates that.
> [...] trying 2 #7 cables
Cat5 would probably be better than you need.
Other than the LED indicator color, do you have an actual problem?
