lveddie's avatar
lveddie
Follower
Aug 06, 2018
ac1200 c6220 running hot
If this has already been posted, I apologize.  Just hooked up my C6220 last week and works great.  I have noticed that the coax connector at the modem seems unusually hot. Top of modem also hot.  Is this normal?
  • Make sure the modem is in a open place with airflow but if it gets way to hot to the touch I would contact support.
    DarrenM
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    DarrenM
    • BPDean's avatar
      BPDean
      I have a new (end of June, 2018) Netgear modem router that is running very hot. It is in an open space with air circulating around it. Is this normal?
